Hej Lennart/LJN
Har skapat en ny tråd ang din fråga om mina OA116.3 med CX21-basar: http://www.carlssonplanet.com/forum/vie ... f=4&t=4247 .
Mvh // Göran
OA116 Renovation
Re: OA116 Renovation
_____________
Som drivs med:
m.m.
_____________
Som drivs med:
m.m.
Hi
Regarding the castors (Wheels) someone in Denmark held a stock of this and I read that someone bought from there.
Does anyone remeber how that went?
Best regards
Best regards
Those wheels/castors (from Denmark) , I bought, was made of nylon and not rubber.Martin Dellstig wrote:Hi
Best regards
Best Regards // Göran
_____________
Som drivs med:
m.m.
_____________
Som drivs med:
m.m.
Hi
From castors online I got the following answer:
We are able to supply the castor with what we call a poly tyre it is not
however shown on the website. They are the same as the untyred ones as
at http://www.castors-online.co.uk but are priced at an extra 80p per castor
and add suffix poly to the code.
The castor I found was:
50mm Shepherd Castor With Peg & Socket Ref: Kenrick 46
Wheel Diameter: 50mm
Fitted Height: 56mm
Load Rating: 50Kg
Fitting: Peg & Socket For Wood Fitting 9.5mm X 25mm
Price: £2.49 (Excluding: VAT at 17.5%)
I did not get an answer asking for the tyres only (to save on postage and time for not having to remove the old castors).
May be this will help others to find a supplier
Rony
Fitted Height: 56mm
Load Rating: 50Kg
Rony
Users browsing this forum: Semrush [Bot] and 49 guests
