In the downloads section there are manuals in PDF format in various languages - unfortunately it seems the OA-116 one stops where the Swedish section stops i.e. about page 9 or so. Would someone who has a paper copy of it be able to perhaps upload the English section please?
If you don't have a scanner just some digital photos would be fine btw (maybe I can even try to clean them up a bit and make into a new pdf for the downloads section..) - thanks!
Dan.
read with great interest unfortunately the main information I was after is apparently on a separate 'folded diagram'? I mean where they explain about the jumpers for adjusting the frequency response.. it's mentioned right at the end just before the technical data - seems it's also missing from the Swedish version.. don't suppose you'd happen to have that as well would you?
Hi
There is some info about this in #6, I don´t think there are any more sheets in English in the manual.
/jörgen
So it's been a while but I finally got around to it: trimmed the images/took some needed pages from the Swedish version/bit of colour correction..
English OA-116 manual in PDF form attached below (if it looks ok perhaps one of the admins can put it on the download area so it's easier to find?)
Hi all,
attached complete OA-116 manual, all languages
also edited Assembly details drawing, where its possible to see the parts and assembly drawing on one page (english only sorry, if some one wants to translate i cam provide PSD file)
also original flyer
regards Teepee1
