OA-2212 XLR connectors
kohngallery
Post by kohngallery »
I just purchased a pair of OA-2212 and they still have the xlr 4 pin connectors. I need to change them. What is the best connector to use, and where do the 4 wires go??? Most connectors have only solder connections for 2 wires. I apologize if this has been covered already but I cannot read Swedish.
Russ
Re: OA-2212 XLR connectors
Post by Russ »
kohngallery
Unfortunately that link is no longer active. Do you have a brief description of what needs to happen? Thanks.
It is active. At least in Sweden. It shows that cable connector (female) pin 1 AND 2 are connected to ground (-) and pin 3 AND 4 are connected to signal (+).
Edit: male changed to female.
kohngallery
Thank you! Still unable to reach website. What new connectors would you recommend?
I use the origninal XLR. I suppose you've read this: http://www.carlssonplanet.com/oa2212.php?lang=en&
kohngallery
Yes, I have read it. I do not have the original speaker connectors, and it is difficult to find 4 pin xlr. And it appears that a new, larger and gold plated connector is recommended.
Banana plug?
http://www.kjell.com/sortiment/ljud-bil ... pol-p37217
But that's in Sweden. Where do you live?
kohngallery
Los Angeles
kohngallery
I can find 4 pin xlr terminals on line somewhere. But what about the recommended upgrade? Something with a larger contact surface? And something that is more current that works with gold plated rca or banana plug inputs on the back of my amplifier?
Users browsing this forum: No registered users and 59 guests
