Tweeter control OD-11
starkiller
Post by starkiller »
Have forgotten what the previous owner told me about the different tweeter levels as controlled by the u-shaped jumper...anybody know? thanks!
starkiller
Re: Tweeter control OD-11
Pretty please..?? :mrgreen:
The jumpers are there to fine-adjust the level of the tweeters. The reason is that the quality of the tweeters (MT20) was a bit erratic, so the Sonab factory used the jumpers to correct the level and they also matched speakers into pairs to perform as even as possible.
You hopefully find a red spot under one of the jumper positions, which is the factory pre-set. Don't change that. If you want to adjust the treble it is better to use the tone controls on your (pre-)amplifier.
Russ
Post by Russ »
starkiller
Yes, i have the blue dot, so that is the factory pre-set then eh?
Well, jumpers and dots on my OA12 are red. Sorry I not remembered when posting that the jumpers also could be blue. :oops:
starkiller
Mine have the blue jumpers but on one of the speakers there is a red dot in a corner...hybrid maybe? :mrgreen: Will be trying them in a corner here shortly and i would guess to have the tweeters aimed along the long wall and not the immediate corner wall..correct?
Russ
Post by Russ »
It´s correct when it sounds good. :D
The red dot in the corner indicates how the speakers should be turned in different positions and is marked with an arrow in the pictures in the manual.
Manual: http://user.faktiskt.se/schmutziger/son ... %20Fra.pdf
Users browsing this forum: No registered users and 123 guests
