How to remove and fix bass tube OA51LE2
Re: How to remove and fix bass tube OA51LE2
This is what I did; I looked for a tube that was 58 mm across (inside). I eventually found it in Bauhaus, it had been some plastic rolled on it. Then I cut of 5 cm and used the same glue that you put on rugs. It sticks immediately! Then my hand was slim enough
so that I could take it through one of the holes and just glue it on the end. Works perfectly!
Thanks Bach4ever,
When I get around to it I think thats what I might try. I am finding the bass very pronounced with bass guitar (I am using A4 paper mod). The rest of the upgrade I am very happy with.
Cheers,
m00seman
Cheers,
m00seman
Users browsing this forum: Bing [Bot] and 85 guests
