New woofer option for Sonab
quadmatrix82
- (50+ posts)
Wondering has anyone tried the new woofer replacement for sonab speakers that superseded the b65 series??
https://www.hifikit.se/sb17nrx2c35-8.html
Any thoughts now this compared to the Peerless sc165 or b65?
Re: New woofer option for Sonab
Why do you write "new woofer replacement for sonab speakers that superseded the b65 series??" What information do you have about that? And from where?
quadmatrix82
- (50+ posts)
This is what hifikit tell me
Since they don´t have the 8 ohm B65oaIV at the moment they of course want to recommend something else. But then they also have to tell you how you should build the filter. The woofer is most likely not "plug and play".
quadmatrix82
- (50+ posts)
My understanding it’s discontinued so I wonder how this new version compares and if modifications may be needed
"new version"? It´s a completely other driver from another company. I might be a good one. And I don´t know if it fits Sonab. But someone has to test and make a correct filter. I´m sure it needs that. If HifiKit recommend that driver they also should provide filter drawings.
quadmatrix82
- (50+ posts)
I believe no filter change is needed I may try it if I need them and can’t repair the original peerless
Have you tried sb17nrx2 in your oa-14 and if so what is your opinion. Does it work?quadmatrix82 wrote: Mon 07 Oct 2024, 12:52 I believe no filter change is needed I may try it if I need them and can’t repair the original peerless
quadmatrix82
- (50+ posts)
No I haven’t tried I managed to repair my original ones in the end
Users browsing this forum: Google [Bot] and 16 guests
