Page 1 of 2
OA-50 upgrade to OA-50.4 can it still be done ?
Posted: Wed 20 Feb 2019, 19:46
by Sjoebergs
Hello,
I'm a recent member (days only) in this fantastic Carlsson universe.
I'm having a pair of Carlsson OA-50 since purchase in the late 80's.
They have been "rudely" maintained over the years, but now i have the time to upgrade the speakers the right way (as the speakers deserve).
I've been studying this site for some time, but I'm still a little in doubt about the komponents and filter for the planned upgrade to OA-50.4
So maybe you can help me out:
In order to upgrade from OA-50 to OA50.4, then I'm assuming that the following speakers should be user
Bass = B65oa-IV (8 ohm) ?, Assuming that B65oa-II is no longer for sale.
Tweeter = Obi T22oa ?
Filter = I could only find an incomplete filter design for OA-50.4 on carlssonkult.se. Can you advice to where I can find the final filter design ?
I assume that the components listed above can be purchased from HiFiKit.se ?
Best regards from denmark
Finn
Re: OA-50 upgrade to OA-50.4 can it still be done ?
Posted: Thu 21 Feb 2019, 11:22
by momus
Read at Carlssonkult.se and let google translate.
Posted: Fri 22 Feb 2019, 07:28
by Sjoebergs
Hi Momus,
Thanks for your advice.
Posted: Fri 22 Feb 2019, 10:54
by STDI!
If you don't understand Swedish please tell me and I'll write in English.
Eftersom du är dansk antar jag att du förstår svenska. Och vi förstår nog danska också.
Jag antar att du redan läst på carlssonkult.se eftersom schemat du visar kommer därifrån. Tyvärr har jag inte hittat de saknade värdena någonstans. Så det verkar som om OA50.4 fortfarande är ett mysterium.
Men vi vet i alla fall att diskanten ska vara t11oa (inte t22oa) och basen enligt beskrivningen är B65oaII. Den basen är ju numera ersatt av B65oaIV. Men enligt uppgift ska de tekniska egenskaperna vara samma för dessa två. Och carlssonkult.se menar ju att de inte heller skiljer från B65 (Peerless 831881).
Diskanten t11oa finns inte heller med det namnet men ska vara samma som ScanSpeak D2606/920000.
Vad har du för bas och diskant som sitter i idag? Har du B65 skulle jag föreslå att du bara byter diskant och fixar filtret så att du får OA50.3. Eller det är kanske redan den diskanten också?
Är det en omkantad originalbas föreslår jag att du bygger om enligt det sista förslaget som carlssonkult.se ger, dvs ny diskant och liten ändring av filtret.
Och är du beredd att betala mycket så är det tydligen OA50 Satori som gäller. Eller OA50LE som blir billigare.
Posted: Sat 23 Feb 2019, 17:27
by Sjoebergs
Hej STDI!
Jeg kan så nogenlunde forstå svensk (kommer jo fra en gammel Svensk slægt i småland, hvor min oldefar udvandrede til Bornholm - efternavnet er Sjöberg) men er ikke helt siker på mine evner med at skrive på svensk. Så jeg prøver med SVANSK ! håber at jeg kan gøre mig forståelig ?
Jeg er enig i din antagelse at OA50.4 (Filter) stadig er et mysterium. Det har ikke været muligt for mig at finde de manglende informationer vedrørende spolerne i forbindelse med filteret.
Min nuværende OA-50 konfiguration er som følger:
- Filteret er det originale OA50 Filter
- Tweeter Vifa D25TG-55-06
- Bass peerless 833599
Grundet nuværende OA50 konfiguration (tror ikke at jeg kan genbruge nuværende komponenter), så tænker jeg at ville gå efter Santori opgraderingen. Det bliver spændende
Tweeter : Satori TW29R
Bass : Santori MW16P-8
Filter som beskrevet på filter billedet.
Lavede også lidt prissammenligning Santori vs. LE og kommer frem til ca. 4000 DKK for 2 x Satori (ikke indregnet Filter), og ca. 2600 DKK for LE (ikke indregnet filter).
Så med mindre jeg overser noget, så har jeg et fint projekt at gå igen med ?
Posted: Sat 23 Feb 2019, 18:42
by Sjoebergs
Et spørgsmål mere, hvis jeg bygger OA50.Satori upgraderingen, skal Tweeter bestykningen være Satori TW29R i 4 eller 8 Ohm ?
Posted: Sun 24 Feb 2019, 17:42
by Sjoebergs
Opdatering, har just nu fået svar from CarlssonKult. Det er 4 ohm der behøves.
Posted: Sun 24 Feb 2019, 18:27
by STDI!
Jag vet inte men jag gissar på 4 ohm. Skälet är att om man söker på TW29R på Hifikit.se så får man ingen 8 ohm. Och jag är övertygad om att den skulle funnits där om det var 8 ohm som grafpro (carlssonkult.se) menade. Se här:
https://www.hifikit.se/catalogsearch/result/?q=TW29R
Här är en länk till en tråd som du kanske kan vara intresserad av. Trådskaparen är grafpro. Det är alltså han som driver carlssonkult.se. Inte heller där framgår exakt vilken diskant det gäller och tyvärr slutar tråden lite tråkigt.
https://www.faktiskt.io/phpBB3/viewtopi ... 17&t=57826
Posted: Sun 24 Feb 2019, 18:28
by STDI!
Posted: Sun 24 Feb 2019, 19:48
by Sjoebergs
Jeg har modtaget svar tidligere i dag fra Carlsson kult og TWR29R skal være 4 ohm i OA50.Satori konfigurationen.
Du skal ha mange tak for din hjælp og links til relateret information. Jeg er klar til at bestille stumperne
